Swap to 3.0 TDi
Hi,
Is it possible to make a swap on 3.0 TDi 240KM without enlargement of the engine compartment?
Actually i have 2,0TDi and it begins to fall so i started mind about change it.
I know that 2.5 V6 was inserted, but I do not know if 3.0 TDi will fit
Edited by kostekw13
Refresh
  • 4 weeks later...
Size wise there is room in your engine bay for the 3.0tdi but sadly the amount of work to fit it and get it running would be a lot. The 3.0tdi is the next gen engine to the 2.5 so the electrics, pipework, mountings etc will all be different to some degree. If you want more power go from a 2.0tdi to the 2.5v6 tdi with a good remap you'll see almost 200hp and lots of torque or try your 2.0 with a remap, you will notice the difference.
