Bmn engine breaking
Hi guys iv got a BMN engine I’m breaking with bottom end issues all parts available
revision c head minus injectors glow plugs cam belt cover and head cover head was skimmed and pressure checked last year with new lifters fitted too
£200
 4x injectors part number is 03g 130 073T would advise you fit new seals before fitting does not come with bolts are these are single use bolts
£300
complete egr cooler set up non leaking
£45
bkd inlet manifold brought to convert my bmn engine but iv lost the bolts so you would have to get these your self
£40
bosch vacuum pump 03g 145 209 c good condition and comes with gasket too recently fitted
£40
turbo oil return pipe was brought new not long ago 03g 145 535 f
£25
almost new thermostat and housing 03g 121 121 D
£25
Almost new coolant flange and sensor 03g 121 132 B
£20
bmn oil pump replaced to find out it’s not the issue so I have 2 of these one 2 weeks old and much older one
£15 and £30
Prices are plus postage but all but all prices are Ono collection is preferred from b98 post code
