SOLD - Philips Silver Vision indicator bulbs & LED reversing lights
I have a pair of PY21W (BAU15s... so offset pins) indicator bulbs they appear silver but flash orange so you can get rid of the ‘fried egg’ look with std bulbs:
IMG_3921
SilverVision on left, LED reversing light on right:
IMG_3920
£7.50
Also a pair of 1156 (BA15s) 80W LED reversing light bulbs, these fit the Yeti, Superb MK3 and Fabia MKI as others have bought them on my recommendations and they are VERY bright so ideal for actually seeing where you are going in the dark.
They also do not give any errors on the above cars so shouldn’t be an issue on others.
£20
IMG_0657 2
IMG_0660 2 IMG_1277_zpsg4k2vuxm
(the top left ones)
These are less than half price already but if you want them all I will do them for £25 (+ P&P)
Edited by Gizmo
Are these still available. Are those led fog light bulbs as well?
Yes they are still available.
The LED fogs were given away ages ago (they were crap)
How much would postage and packing be for the lot
£3.50 should cover both pairs
And definatley no errors. As every pair of no error number plate leds i get bring up error codes
I hadn’t actually included the No. plate LEDs but can chuck them in for you. Those do require coding with VCDS though to not give an error (IIRC the coding will only work on the facelift Yeti)
I have numberplate leds i was just using that as an example. Although if you could send me a pm with the coding for my vcds guy to do that would be great. How would you like payment
  • Gizmo locked this topic
Guest
