Firewall passage?
Should exist on on the MK3 – but where is it? Want to install a button for aux-lights instead of cutting on the high beam cable.
No one?
Have you looked behind the Battery? There should defo be one on the Near side where cables go inside the cabin. You will need to remove the battery and look deep behind, you should be able to find a thick cable bundle going through a rubber bung.
