Replacing wishbone bushes - Fabia
Techie querie here - 1.4MPI Fabia (2001)
I'm looking to replace the bushes at the rear of the wishbone onto the main crossmember - they seem to be plastic. I'm a bit nervous of doing it because on most cars you the bushes are on the wishbone, so you can remove the wishbone and bash it about a bit, but this is on the cross member.
Are these bushes easy to remove and replace, or is there a special VW group tool? They are the same on my other Polo.
On another query, the red warning light for coolant level/temperature seems to be faulty and beeps a flashes constantly. Coolant level is fine, temperature is fine (light even comes on when the engine is started from cold) - is there a sensor inside the expansion reservoir gone wrong or whats the story?
Any help would be much appreciated as I dont want to start banging away at these bushes and wind up putting the car on a trailer to my nearest Skoda garage.
1. There is a tool set to withdraw the bush in situ or you can remove and press it out. Or buy the console complete.
2. Search, been covered loads.
2. Search' date=' been covered loads.[/quote']
Remove the crossmember to push it out?? Are we talking about the same thing?
Where can I get the tool and how much roughly for?
