Fault codes
Cannot  find  any information  on these  fault  codes using carista any help please
Obd2
P011f
Can gateway
8531970
Instrament cluster
9456433
Engine
09606
The OBD code is easily available online as EOBD is standardised for all European sold cars.
P011f Temperature Sensor outside of spec. It isn't clear if it's the coolant temperature sensor or the outside air temperature sensor. The engine fault code will probably be more specific.
Found out it was the engine coolant temperature sensor being replaced under warranty.
