P0405 EGR sensor 1 Fault. CFWA engine
Hi all got a fault on my 1.2 tdi ecomotive CFWA engine
 btw it is a Seat Ibiza 2011 so should be safe as Fabia engine
15536 Egr sensor 1 P0405 00 (175) signal too low
Cleared it but comes on after a couple of ignition cycles
Any ideas of this fault?
There is no such 1.2 TDI engine in the MK3 series, the CFWA engine was used in the MK2 Fabia though, perhaps this post should be moved there.
Edit; on a side note, get your EGR valve checked out by dealer or independent garage, might be clogged with carbon build up, or the sensor could be bad.
Edited by FabiaGonzales
