Wont Start on key
Any thoughts 2010 yeti 4x4 with the 170 2.0 engine with over 200K on the clock.
Recently had a replacement HPFP and cam sensor plus cam belt and water pump. But today just wont start on the key.  Can turn the car over and over and wont start. A quick squirt of easy start in the air intake and the car will start and tick over. Turn it off and  wont start.
Faults logged
Address 17: Instruments (J285)       Labels:| 5K0-920-xxx-17.clb-SRI1
   Part No SW: 5L0 920 940 E    HW: 5L0 920 940 E
   Component: KOMBI         H08 0305
   Serial number: 00000000000000
   Coding: 720D00
   Shop #: WSC 62021 220 97033
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04052
   ROD: EV_Kombi_UDS_VDD_RM09_004_SK34.rod
   VCID: 2E57F09C71F3363A7F-807A
1 Fault Found:
9453074 - Fuel Level Sensor 1
          B103E 1B [008] - Resistance Too High
          Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 226
Address 19: CAN Gateway        Labels:. 1K0-907-530-V4.clb
   Part No SW: 1K0 907 530 AD    HW: 1K0 907 951
   Component: J533  Gateway   H16 0233
   Revision:   H16       Serial number: 4520K102030132
   Coding: E9A37F06500602006303
   Shop #: WSC 33361 790 00999
   VCID: 69DD4380409D91026A-803C
1 Fault Found:
00470 - Company Comfort Databus in Single Wire
            011 - Open Circuit
             Freeze Frame:
                    Fault Status: 01101011
                    Fault Priority: 3
                    Fault Frequency: 254
                    Reset counter: 187
                    Mileage: 327368 km
                    Time Indication: 0
What's one of those?
High Pressure Fuel Pump
Then that or the cam position sensor is playing up then.
Do you really think it could be the cam sensor again ?
