DRL
Hello fans skoda octavia! Do you know that the daytime running lights are switched off when the xenon light is on? The headlamp with xenon
They should dim. But not turn off.  Assuming we’re talking about the Xenon cluster with the LED strip as the DRL.
Edited by SC03OTT
1 minute ago, SC03OTT said:
Ar trebui să-i diminueze. Dar nu opriți. Presupunând că vorbim despre clusterul Xenon cu banda LED ca DRL.
I'm talking about the led strip stopping when the short beam is on
My comment stands then. It shouldn’t turn off it should only reduce in intensity. If yours is turning off then it’s been coded to do so, either intentionally or unintentionally.
Acum 7 minute, SC03OTT a spus:
Comentariul meu este atunci. Nu ar trebui să-l oprească ar trebui să reducă doar în intensitate. Dacă ta se oprește, atunci a fost codificată să o facă, fie în mod intenționat, fie neintenționat.
I ned coding turn of. I want turn of
If it decreases the intensity below 20 on daytime lights when it has signaled an error in the dashboard that daytime running lights are not working.  when you signal more than 5 times
