Mk2 retrofit cruise control
Hi everyone, I’m retrofitting cruise control to my 2008 Skoda Octavia 1.9 TDI BXE. I’ve fitted the cruise-control stalk and wiring is in place, and coded the steering-column module using OBDeleven. The stalk appears to be recognised in the steering-column live data, but I haven’t managed to get cruise control working yet. I’m now trying to code the engine ECU (01 – Engine), but OBDeleven displays “Access authorization required, perform Login.” Has anyone successfully activated cruise control on this ECU, and could advise me on the correct login/security access or coding procedure? Any help would be appreciated!
