cruise retrofit
just fitted a cruise control STALK to my 2008 pre-facelift octavia, tried it down the road , but it`s not working, does anyone know what i need to do to get it working, can anyone code it for me, i live in hemel hempstead, but am willing to travel to somebody and pay them, if they can help?
thanks.
When I had mine fitted, it needed to be programmed in with the correct software.  Maybe there's someone down south that can help do that?
that`s what i thought, i thought there might be a member on here who could do it for me ?????
I can do it for you, if you fancy a trip to Milton Keynes?
Trev
Its the main engine control ECU that needs coding, it can be done with VCDS, I had to enable it when I swapped to a remapped ECU.
Post overlapped, I'm sure Aston Bodger already knows this.
Also the steering module needs recoding too.
Trev
Good to know, mine not being a retrofit was already coded.
I guess then that cruise control will be switched off if you grab an armfull of opposite lock :D
Possibly.
But the steering module needs to know it has a cruise stalk fitted, hence if yours had it already, you did not need to code it.
Trev
well thanks for the info lads/lasses and those who are still debating their sexuality, very useful info, BUT who can actually do the recoding please???
Like I said in the reply to you, I can do it for you, if you fancy a trip to Milton Keynes?
Trev
well  that`s awful nice of you revver, where/ when and how many sheckeles is it going to cost me ?????
didn't mean to upset you trev , I`ve got a mate called trevor and his nicknames "revver" hence I call all trevors "revver" !
Nah, takes more than that :D
You have PM
Trev
  • 3 months later...
Hi Trev, just need to pick your brains AGAIN ! was thinking of having a remap on my 105 PD Skoda, someone mentioned the 5 speed gearbox was a bit weak on these, do you know if it's true, and if it's not, can you recommend someone who can do a remap that doesn't cost a fortune ?
Jerry
Edited by gee57
Mistake
I wouldn't say the 5 speed is particularly weak, map shouldn't bother it at all.
Darn good remaps @ Unit18
Edited by Tech1e
Lots of people rave about "blacksmoke" for a 1/4 of the price....anyone done  this on the 105PD ?
The DIY remaps? You pay's ya money, ya takes ya chances.
