P2015 - Unable to run adaptation on intake flaps
I have a P2015 code (but strangely no EML...) which I can reset and comes back:
Quote
008213 - Intake Manifold Flap Position Sensor (Bank 1)
               P2015 - 000 - Implausible Signal
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 0
                    Fault Frequency: 2
                    Reset counter: 255
                    Mileage: 91338 km
                    Time Indication: 0
                    Date: 2013.09.26
                    Time: 19:33:48
             Freeze Frame:
                    RPM: 769 /min
                    Load: 20.0 %
                    Speed: 0.0 km/h
                    Temperature: 60.0°C
                    Temperature: 26.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 13.970 V
Checking out blocks 142/143 I see that the sensor shows 0% at idle and and when I move the arm it shows 99.2% so it seems the sensor is working? When running the adaptation it moves via the solenoid and shows 0% to 99.2%, but then the adaptation fails and shows "ERROR" in the last field:
Quote
Address 01: Engine  (1Z0 907 115 AF)
19:42:20 Group 142: Fuel Supply System (Intake Runner Flap Adaptation: Bank 1)
  0.0 %  Runner Flap B1 Position (act.)
  0.0 %  Runner Flap B1 Position (spec.)
  4.380 V  Runner Flap B1 Position Offset
  ERROR  Runner Flap B1 Adaptation
I'm quite confused, so any help is appreciated!
Anyone got any ideas? :D
There is a common fault where the manifold flaps carbon up and stick
[EDIT after searching]
Edited by bigjohn
Yup, but running the adaptation shows they have a full sweep
