Cav engine
Hi chaps can you fit a cthe engine into a cave engined car.
Welcome.
You could, with the ECU.
Do you need to, is your CAVE gubbed?
Also thought this engine and ecu swap but i beleive you have to change the clocks and control body?
Id much rather put a totally different engine in not a skoda one
Edited by GT0161
Just out of curiosity what engine would you put in that wasn’t skoda? Toyota hybrid? 😂
Edited by LGM
@LGM Something that wont burn oil and blow up
If it was all so simple.
I have actually just fitted the cthe engine. Took it to bear bones and fitted all sensors injectors and wiring loom from cave . Fingers crossed for start up tomorra.
Get some pictures up mate!
Car started 1st turn of key and runs perfect. Cthe will fit in cave car
@Brandonh
Can you share your story please,
where are you, and what happened, did you have a CAVE engine car that went bad or did you buy one knowing it was bad,
then where did you manage to find a good CTHE ?
