Hid coding
Does anyone in or around the derby area offer the coding for non canbus hid kit via vcds. I've had an error free kit fitted for 2 weeks and now removed and ordered a non canbus system due to reading lots of comments regarding blowing the wiper motors and the control module for the lights.
Also what do others upgrade to on the h1 high beam and the h1 fog lights.
Cheers Dan
Anyone shed any light
You should try contacting a local member with VCDS, couple of threads to help:
- https://www.briskoda.net/forums/topic/262215-list-of-vcds-owners-previously-known-as-vag-com-vcp-owners/
- https://www.briskoda.net/forums/topic/224376-vcds-owners-map/
As for the high beam, I'd stick to decent halogen bulbs as they'll give you better distance lighting which is the entire point of high beams.
Not sure any particularly good LED H1 fog lights exist, at least I've never seen any that I'd want to fit. I think some people take the LED fog lamp from a Fabia (maybe?) and fit in inside an Octavia housing, probably worth a search.
