Best place to locate a clock spring for my Octavia - Part - 5K0.953.569.e
Hi All.  Hope someone can help.  Following an earlier thread of mine a mechanic pal of mine tried to fit a replacemnt unit to our car.  The part was incorrect, and I am in the process of returning it (tried my luck with ebay)
The actual part in the car is  5K0.953.569.e    Does anyone know where I can purchase this part?  I've seen second hand ones on ebay for about £90, and looks like it is the same part as is fitted on a Mark 6 golf.   I'd like a new one if possible/ reasonable cost - but if not, I'll head down the second hand route.
Thanks.
M.
FYI it's available from skoda-parts.com for Eur292.92 plus about Eur 10 shipping.
It was fitted to all FL Octavia 2s so you might be able to find one in a breaker:
1.2 TSI 77kW/105PS CBZB 02/2010 → 04/2013
1.4 16V 59kW/80PS BUD 11/2008 → 06/2013
1.4 16V 59kW/80PS CGGA 11/2008 → 06/2013
1.4 TSI 90kW/122PS CAXA 11/2008 → 06/2013
1.4 TSI 96kW/134PS CFBA 03/2010 → 05/2013
1.6 MPI 75kW/102PS BSE 11/2008 → 06/2013
1.6 MPI 75kW/102PS BSF 11/2008 → 06/2013
1.6 MPI 75kW/102PS CCSA 11/2008 → 05/2010
1.6 MPI 75kW/102PS CMXA 11/2008 → 06/2013
1.6 LPG 75kW/102PS CHGA 08/2009 → 11/2012
1.8 TSI 112kW/152PS CDAB 03/2009 → 06/2013
1.8 TSI 112kW/152PS 4x4, SC CDAB 03/2009 → 02/2013
1.8 TSI 118kW/160PS BYJ 04/2007 → 03/2010
1.8 TSI 118kW/160PS CDAA 11/2008 → 04/2013
1.8 TSI 118kW/160PS 4x4 CDAA 11/2008 → 02/2013
1.8 TSI 118kW/160PS CEAA 03/2010 →
2.0 TSI 147kW/200PS RS CCZA 11/2008 → 02/2013
2.0 TSI 180kW/245PS RS 245, 6S, 7A DHGA 02/2017 →
1.6 TDI CR 77kW/105PS CAYC 06/2009 → 04/2013
1.6 TDI CR 77kW/105PS 4x4 CAYC 06/2009 → 04/2013
1.9 TDI PD 77kW/105PS BJB 11/2008 → 04/2013
1.9 TDI PD 77kW/105PS BLS 11/2008 → 05/2010
1.9 TDI PD 77kW/105PS 4x4 BLS 11/2008 → 11/2009
1.9 TDI PD 77kW/105PS 4x4 BXE 11/2008 → 12/2010
1.9 TDI PD 77kW/105PS BXE 11/2008 → 04/2013
2.0 TDI CR 81kW/110PS CFHF 02/2011 → 04/2013
2.0 TDI CR 81kW/110PS 4x4 CFHF 05/2011 → 02/2013
2.0 TDI CR 81kW/110PS CLCA 03/2010 → 06/2013
2.0 TDI CR 85kW/116PS DFGC 03/2015 →
2.0 TDI PD 100kW/136PS AZV 11/2008 → 05/2010
2.0 TDI PD 103kW/140PS BKD 11/2008 → 05/2010
2.0 TDI PD 103kW/140PS 4x4 BMM 11/2008 → 05/2010
2.0 TDI PD 103kW/140PS BMM 11/2008 → 05/2010
2.0 TDI CR 103kW/140PS CFHC 02/2010 → 05/2013
2.0 TDI CR 103kW/140PS 4x4 CFHC 05/2010 → 02/2013
2.0 TDI CR 103kW/140PS CLCB 02/2010 → 05/2013
2.0 TDI CR 125kW/170PS RS CEGA 11/2008 → 02/2013
2.0 TDI CR 130kW/177PS NCZ CRGA 03/2015 →
Thanks for that Micky - very helpful, though eyewateringly expensive.   I'll think I will try a breakers yard!
1
Here's one on fleabay that looks promising - and "only" £119.99 :)
Also worth a look on gumtree and preloved to find someone breaking the correct car - maybe near you?
Another trick is to put a request into one of the premium parts search sites - like parts finder - and then use Google{tm} to find a normal phone number for any hits you get instead of paying through the nose to use the premium numbers they offer you.
Given that it operates the airbag, which is a very effective and safety critical subsystem, they're not that expensive! Skimping by buying one from a breaker might be though!
