dip headlight and daylight not working
dip headlight and daylight bulbs not working. all bulbs are ok. back fed system and they work
Welcome.
Help someone help you.  What age of Mk2 Fabia and what trim / model?
2013 1.6 diesel. elegance estate
Fuse went?
8 minutes ago, AMD87 said:
Fuse went?
27 minutes ago, Roottootemoot said:
Welcome.
fuses are ok, but seems low reading on meter on one side of the fuse.
What do you mean by back fed system?
10 minutes ago, AMD87 said:
Fuse went?
i put a 12v supply onto connection at lamp holder. headlights lit. also at fusebox if a 12v is applied to lamp side they light. it appears that the volts on the feedside is low. do not know where this comes from. and do not have a wiring diagram
Wow, the BCM is gonna love you punting 12v down a wire.
Any fault codes?
Any fault codes?
do not have a diognostic machine. no codes on dash etc
where can i get a free wiring download for the lighting system
