Instument cluster
Hi guys after a little advise, my 2007 pre face lift Octavia speedo needle has stopped working its been repaired once but has only last about 8 months
so im now looking at replacing it with a second hand one, i have found one on eBay that is the same part number (1Z0 920 910C )
now from doing some research on here it looks like i will need the SKC code for both panels to be able to program the second hand unit to the car is this correct?
Can the millage be put into the second hand speedo so it matches the car?
and can anyone recommend anyone that can do this for me close to the Doncaster area?
Rob
On some clusters you can do it with the SKC
If it is the newer 2006 onwards, SKC method doesn't work
I can do it but I'm not near you. I'm in Great yarmouth
If you can find a maxidot that would be an upgrade
Thanks for the quick reply Eddie
Mine is 2007 57 plate TFSI Vrs if that make any difference?
Had a quick look into the maxidot upgrade but wasn't to sure which instrument cluster i would need to do this and i guess i would have to upgrade the stereo at the same for it all to look right?
No need to upgrade the stereo for a maxidot
I think the part number for a maxidot would be 1Z0920942C
and what is required to put a maxi dot into my car?
how do i go about checking that part number is correct for my car? there is one listed on eBay for sale not to far from me if its definitely that part number?
thank you for the advise!!
