Boot light
Hi All,
Ever since I bought the car, last year, the boot light hasn't worked.
How can I check if this is a fuse, or the bulb, or something else?
And if it's a simple bulb, how do I replace it?
Thanks,
Damian
The boot and glove box both require fuse to be taken out. You can check the boot by swapping the 1 of the 2 map reader bulbs (if you have this configuration)
Hi Kobayashi,
Do you mean that I should try the glove box bulb in the boot?
I'll take a look.
Thanks,
Damian
Yes you could that but easier to pull out one of the map readers there's usually 2 next to the main festoon, I think when you replace a bulb its 50/50 chance of working as positive / negative, so turn other way if doesn't.  I replace all mine with LED
This was an east one to fix.
When I removed the boot bulb, I could see that it just wasn't plugged in!
Luckily, the wire was right there, so I scooped it out and plugged it in.
Now all is well.
Almost a year without it and I just needed to plug it in! 🙂
