Almost there !!!
As you know from previous threads ive been chasing boost leaks and power loss.
Pcv changed - slight improvement running
Diverter valve changed - no difference
Full service - no difference
Unplugged maf - 20% better but still down
New o-rings from turbo to intercooler ( 3 ) -
Much much better and less noise
Unplug maf after o-rings- even better still
Conclusion !
Car has been poorly maintained, boost leak was obviously o-rings but the ones i removed were green so had been changed at some point, and faulty maf as unplugged it runs better power than plugged in.
Next job is replace o- rings on throttle body side of intercooler and replace maf, i am assuming that with maf unplugged it is running a base setting, that setting is still quicker than plugged in so should have better performance when replaced.
Yup, new genuine maf will be much better.
Dont get a pattern one... youl just end up buying an oem one is 3-6months time anyway.
