Boost restored then missfire
Today i finaly sorted my boost issues, fitted new map and enjoyed power for all of 30secs, then ecu light flashing and drops to 3 cylinders, tick over perfect but soon as you move 3 cylinders, could it be cheap red coil pack ?
It definitely could be a coil pack. Or plugs. Are you running r8 coil packs.?
Cheap copy r8 coil packs, 3 weeks old
I’d  by an oem quality pack and start swapping. Then, if it is the problem probably replace them all. Unless you have the originals...
Binned originals but just ordered a oem set, pretty sure its a toasted coil, all the symptoms under load but not tickover
Update, pulled plugs today, plug 4 soaked in fuel, looking like one of new coils
