Torx bits.
Perhaps a post advising gran on removing interior from eggs, but it might be of use to some.  Toolstation do a set of bits for circa £16 , or individual ones for £1.08
 I only bought the size I needed ,but I note that a lot of other sizes are available.
I always recommend this set: https://www.drapertools.com/product/33322/Draper-TX-STAR-Hexagon-and-Spline-Mechanics-Bit-Set-(40-Piece)
Almost all of the bits you'll need to work on VAG stuff (there are a few special Torx/XZN bits for stuff like gearbox drains that you will need to buy individually).
If you're on a tighter budget, there's a non-'Expert' version too: https://www.drapertools.com/product/33323/Draper-TX-STAR-Hexagon-and-Spline-Mechanics-Bit-Set-(40-Piece)
Edited by chimaera
The Expert one is exactly the same as the one I have been using probably for 20 years now, think it came from Machine Mart when I bought it, never had to replace any of the bits in that time.
TBH the non expert looks identical but with a plastic case.
On mine- gearbox plugs ( like almost all of the cars I've had/worked on in over 50 years of motoring) are the traditional square typical transmission ( gearbox/diff) size. I mentioned the Toolbox route as a way to get decent torx bits ( in sizes you might need) at a reasonable cost, buying th bits you need as you need them .
