Skoda Octavia 2 pre-FL retrofit
Hello, guys, I own a late ‘07 Skoda Octavia mk2  and I want to know if it’s possible to install Octavia 2 facelift instrument cluster and climate control.
sorry for my english.
where are you located?
Romania. Why?
On 26/11/2019 at 14:37, mihaib1234 said:
Romania. Why?
because if you were in UK I could help you, i have fitted several
Could you please tell me what do I have to buy in order to install facelift instrument clusters on my pre-fl O2?
Facelift Cluster
Adaptor Loom 36pin to 32pin
2x Id48 transponders
You might also need, check what you have
Gateway that support UDS 1K0907530L or above
MK70 ABS Pump AF or above
Mk60 ABS Pump Q or above
Thank you! I will check it out as soon as possible!
On 29/11/2019 at 12:07, Eddie-NL said:
Facelift Cluster
My ABS Pump is a MK70 one, but I don't know the exact code, I'll ask a friend with VCDS to check it. Also, what do I do with the ID48 Transponders? Do they go inside the instrument cluster or the keys? How do I pair the keys (I have 2) with the car after installing the instrument cluster? Thank you for your help!
you need to find someone with a tool that can read your immo data and program new keys
Is it possible to program keys and read immo data via VCDS? Thanks!
No you need another program in order to program the keys new transponders with the immo to the cluster. Both can be programmed when all the old immobilizers have been copied from the car. Then you dont even need the car to program it.
  • 3 years later...
Salut Mihai, ai rezolvat pana la urma problema ca și eu am o O2 din 2009 nonfl și as vrea sa i pun ceasuri de fl și as vrea sa stiu procedura amănunțită. Merci!
