Reversing Lights & Sensors no longer work after Clutch & Flywheel replacement.
Hi again. So I've just had my car back from the garage after a Clutch and Flywheel replacement which solved all issues in my previous post. I have noticed a few things since however:
I can engage reverse fine with no grinding or clunks etc... but my Reversing Lights and Parking Sensors (Rear) no longer work/engage. Typically when going into reverse there is a second-long beep, any music is turned down and the Parking display is shown on the radio however this no longer happens and there are no reversing lights. I have no warnings on my dashboard so I'm not really sure what it could be.
Does anyone have any idea as to what this is?
Sounds like the reverse switch hasn't been reconnected or the wiring to it has been damaged. Probably worth speaking to the garage that did the work :)
Okay, thank you for the reply. I will be doing this tomorrow and will update you on what the outcome is. :)
Garage found that they forgot to reconnect the reverse switch as you said. It's all fixed now, Thanks!
