Airbag trouble
I have problem with my airbag, in left chair i have resistance 2ohm because the airbag dont work and the warning light on my disply.
The diagnos tell me this:
"Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 S    HW: 1K0 909 605 S
   Component: Q2 AIRBAG VW8   026 0800
   Revision: 09026000    Serial number: 0038ND0WJ37M
   Coding: 0020786
   Shop #: WSC 73430 790 00000
   VCID: 3C70EFB27FF0E7AF85-8068
   Subsystem 1 - Serial number: 633  SME
   Subsystem 2 - Serial number: 6342MSME0D5611378
   Subsystem 3 - Serial number: 6351HSME09000A781
   Subsystem 4 - Serial number: 6361HSME0873167EE
1 Fault Found
01221 - Crash Sensor Side Airbag; Driver Side (G179)
            010 - Open or Short to Plus - MIL ON"
I have change the central unit 1K0 909 605 S and in the driverseat i have 2 ohm resistanse.
Any solution?
It will be either the yellow connector that is found under a plastic removeable trim cover in front of the seat rail or in my case turned out to be a little known secondary connector tucked up under the seat squab.
Looking through the service history the car had been plagued by this fault for years costing previous owners literally thousands in unecessary work and resets including the alleged replacement of the airbag which had not been done.
Edited by J.R.
  • john999boy changed the title to Airbag trouble
I have the 2 ohm resistance in that connector you tell me aboat  infront of the rail. Maybe it can be the airbag on the sideprotesion. https://workshop-manuals.com/skoda/octavia-mk2/body/body_work/passenger_protection/airbag/summary_of_components_of_head_airbag_unit/
Actually reading carefully it says that its the crash sensor not the airbag, not sure where it is located but have a feeling it might be in the door in which case a broken wire in the hinge grommet would be a likely suspect.
Hi JR,,, yes it is the chrash sensor so now must i try to find them.
crash sensor
