D/S rear window not working
I have recently bought a 2012 yeti Elegance and so far very pleased, I have only one issue in that rear d/s electric window does not work and wondered if anyone can give advice as due to Covid-19 garages are closed. I also if anyone can help , does this model able to open and shut windows via remote as again unable to get working
Does the window operate from the switch on the rear or drivers door?
If not I suspect a broken wire between the "B" pillar and the rear door, are you able to pull the boot back to look at the wires?
That model should be able to open and close the windows and fold the mirrors from the fob, the mirrors should fold by holding the lock button for about 2 - 3 seconds when locking.
If that does not work have you lost the "one touch" opening and closing on any windows, if yes close the window on door switch and release the button, then hold button up for about 5 seconds and it should restore the windows one touch and the mirrors ability to fold from the fob
hello and thanks for reply, i will try this, however rear d/s  window does not operate on door or at drivers main switches
Then assuggested you need to check the wiring between the door and the door post/B post.
