Door seal replacement.
Has any one replaced the drivers door seal? Is it easy?
Just pull the old one off and knock the new one on with a rubber or wooden mallet. Holding the hard plastic lower trim away from it just a little as you do so helps it seat better. Make sure the seal is pushed into the corners properly around the door aperture and flip the inner lip out over the adjacent trim pieces.
Thank you very much.👍
  • 1 year later...
can anybody please help with a part number for the door seal? fabia mk3 5nj
I just rang up my local Skoda dealer and ask the parts department for a quote and to tell me the part number.
Unfortunately I don't have a record of what the part number is myself.
I think it is 6V0 867 365 J 5AP    and  6V0 867 366 J 5AP but are there better ones than the original ones? I would like to reduce the noise from outside at high speeds.
Until which speed is the noise ok in your car?
Edited by Burtus
