Tire pressure fabia 3 helo
hello please how to activate the tire pressure control on skoda fabia 3
On the screen panel select "Car" then it comes up on a list of various things you can do. BTW there are full details of how to do it in the user manual, have you not got one?
no I am trying to activate it I am looking for the encoding of the ABS so that I can activate it
Sorry I do not understand what you mean by "activate it". It quite clearly states in the manual that if you want to tell the car that you are happy with say 2.0 bar tyre pressure then you should change your tyre pressures to that (with a pump and guage) then go to "CAR" on the display then select "Tyre Press" followed by "SET". Its all on page 128 of the manual and is nothing to do with ABS.
@Biilou2020  Where are you, and is it a country that got Mk3 Fabia without a Tyre Pressure Monitoring System as standard, or have you reset it or deleted ?
Edited by e-Roottoot
it has the tire pressure system but i need the abs coding so i can activate it
