Rear window washer fluid leaking into driver footwell. Citigo.
Hi,
I have a 2012 Citigo.
when I engage the rear window washer I get fluid leaking down onto my feet.
Anyone experience this before or know how to get at the pipe to find the leak?
Thanks in advance..
C
  • 3 years later...
I have the same problem  only fix I did was to disconnected  the pipe  off the washer  pump that supplied  the rear washer as it dumb water over the fuse box and plug to ecu
