Fuse
Hi guys before I make a major mistake what size fuses do I need for the car are they mini standard micro thanks for the help
There is a mix of fuse sizes, most are either regular or mini if I recall correctly.
I'd suggest you take a picture of each fusebox so you know both what's fitted and where they belong!
Yes, micro and mini blade fuses are required. What fuse did you blow?
  • 3 years later...
If the alarm and immobiliser  don't work could it be that there are no fuses for them ? If so where do you buy these fuses ? Should csr be taken to a Skoda dealer to get them replaced ?
Edited by Jemm
Extra info required. Thnx.
The immobiliser isn't a separate thing, it's built into various modules like the ECU and instrument cluster. Bypassing it isn't as simple as just removing fuse(s) :)
