SKODA OCTAVIA
I have a Skoda Octavia DSG automatic and have front and rear electric windows but all the windows except the drivers windows have automatic up and down where's the drivers window has down but you have to keep your finger on the wind u to get it to the top can i get this altered in anyway >>
The windows do throw a hissy fit occasionally and malfunction. The owners manual has a paragraph or two about the reset procedure. It’s been posted on here a couple of times before too.
Page 41 of the owners manual:
The automatic power windows do not work if the vehicle battery was disconnec- ted and connected while a window is open. The system must be activated.
Proceed as follows in order to re-establish the function:
› Switch on the ignition.
› Pull the top edge of the button and close the window.
› Release the button.
› Pull the relevant button upwards again for approx. 3 seconds, and keep it press-
ed down.
In the winter, ice accumulating on the surface of the window may cause there to be more resistance when closing the window. The window will stop and move back several centimetres.
It is necessary to deactivate the force limiter to close the window » page 40.
I had this and no matter what I did it didnt work. Turned out to be the window switch itself for me.
Mine is exactly the same. All work one hit except the drivers. I'll have a go at the reset above and keep you posted.
Tried the reset above but doesn't work
Yeah doubt mine will either. Probably new switches required.
They do work so going see hm a new sensor will be so it goes up one pull
