Radio unit, Parking display acting odd
Hey,
Has anyone had this before? Facelift 09”
This morning noticed that my parking sensor display does not show up. I can hear it though when in reverse. It functions all well, just without the display. Also noticed that the radio displays time is 2 hours late. So it’s in gmt now. Cockpit shows the correct time which is gmt+2. Also being in reverse, does not make music/radio more quiet like it used to before. Parking lights are working.
Also when radio was turned off, it used to show the time. Now it’s all black.
What’s happening 🤨
Edited by CozyTony
Possibly it lost its settings or they were corrupted when trying to start the engine with a bad battery/cold weather cranking.
You should be able to go through the radio menu and set things right.
I’ve tried doing a factory reset without success. I don’t believe that there are any settings for these issues. Also tried factory resetting PDC, no effect.
Scan it and see if it gives any pointers.
Update, if anyone ever finds this thread.
TL;DR - Updating the radio unit software firmware solved the problem.
I tried to find ways to reboot the radio system, because I also noticed that the radio would not turn off, even with ignition off, and leaving the car. This car is fitted with Amundsen, RNS310. I could not find ways to reboot (tried <, >, i combo and power button hold) System software was 0045 I think, so very old. I updated the firmware, to 351 and it began to work like it used to. Currently updating to 357.
