ABS, TCS & Tyre pressure warning lights on
I knew I shouldn't have done it.  Friend of mine asked me yesteday how the Superb was going and like a fool I said it was all wonderful.  Just poped up to the shops now and dashboard lit up with ABS, TCS and Tyre pressure warning lights.
I'm assuming this is wheels speed sensor as would not expect the others (yaw, acceleration and so on) to also affect the TPMS (although I've bee surprised before).
Obviously I need to work out which wheel is at fault and the way forward is with a scan.  Question is though do I need VCDS or will as 'simple' scanner do the job?
Car is a 2008 Mk2 if that will make any difference
Edited by Gdcobra
