Electric tailgate opens fully, then lowers a bit?
When I open the boot, it opens fully as I would want, but then immediately returns back ~20cm. I pushed it back up and long-pressed the closing button to save the position, but it does not help. Is there some other feature in play or is there some problem?
You’ll need a scan, could be a faulty strut but they aren’t expensive used or third party.
  • 3 months later...
Hi, I tried to scan with Carista OBD, not sure if that counts as a "scan" as you meant it, but it didn't tell anything about tailgate. I tried to investigate which side is faulty by unplugging them separately and trying to operate, but I only get a single "beep" sound whenever I try to open or close, so it seems it does not even try with either unplugged. The other side is clearly more noisy when operating. I wonder is the noisier the healthy one or the faulty... New one (single piece) seems to be 450 eur around here 🤑 I'd rather have broken tailgate than pay that haha, but would like to investigate the motor myself.
Struts from Skoda are £405 .... Ask me how I know :D Luckily they are sorting mine under warranty ..
Do you know are the right and left really different physically? They have A/B difference in product number but one would imagine such thing could be built symmetrically. In case I cannot figure out which one is bad, I could buy one used and just try...
can you not replace struts with manual struts, should be a lot cheaper
I believe you can but as Sasha says the power struts can be had much, much cheaper if you look around and seem pretty easy to replace.
This is not necessarily the case as you would also need to change the boot lock, remove the soft closer, change coding, change the ball joints and buy gas struts. New aftermarket or good used struts can be had quite cheaply. I retrofitted the power tailgate to my Octy and those struts are hella expensive but even then I got used ones for a not unreasonable price. I was tripping over used Superb struts from £60 a side and the power bootlid is such a boom IMO it’s worth it.
  • 6 months later...
Hi Sasha where you would recommend I look for such items for my octy scout please? Are the struts all I need or is there with items??
There’s a lot more you need.
latch and motor
struts
wiring loom
control module
I’m assuming you have a manual boot
latch and motor
struts
wiring loom
control module
Yeah that’s right - would have been nice to just buy a ‘kit’ but ah well, I’ll continue to use my arm 😊
You can buy a kit for the mk4 which is about £600, probably similar price for the mk3 kit. Then a lot of wiring.
I've had this issue. I opted to let it drop then press and hold the button. Now it doesn't drop slightly after opening.
  • 7 months later...
3 hours ago, Stuom said:
Just wanted to update here, bought two of these https://www.amazon.de/dp/B08L555ZNH?ref=ppx_yo2ov_dt_b_fed_asin_title and managed to change myself as a complete noob, and they have worked for 2 years now
How did keeping the tailgate in the open position go? I imagine that's the most difficult part. I suppose you could carefully reverse to a solid object with something to protect the edge of the lid.
I also wonder if replacing just one side could potentially fix the problem, but I guess there's only one way to find out..
It was not hard, you basically need one or two sturdy sticks that you place between the floor of the trunk and the tailgate. I think I used two extendable paint roller poles I had lying around with some extra tape to make sure they stay locked :D With adjustable length it was easy to find a place for the poles that I trusted they won't budge even if I accidentally bump them a little.
Somebody suggested to change both struts especially if they are different than original, since it's possible they have a little different motor/speed, and then the left and right sides might be out of sync and fight each other
Edited by Stuom
