Window Open Help Needed URGENT!
All my windows have stopped working however the drivers window is open and I am unable to close it. Is there a way I can manually close it for tonight?
Thank you
You probably tried this, but have you pressed and held the lock button on your key for a few seconds?
Edited by Gremlin170
Yep, it appears to be a power thing as the speaker does not work or mirror in that door, although no other window works either!
Try checking the fuses.
Drivers door wiring loom.  Check the gaitor in the door jamb. It’s so common in the last 6-12 months and on Superbs
