How to configure charging on PHEV
Hi,
Got by RS PHEV about 2 months ago, so far a pretty nice car with pretty bad software, but that's not why I'm here today.
I would like to achieve the following
 - when at home I want to plug the cable in, but have the car charge between 23:00 and 06:00 (during off peak hours)
 - when I'm at a public charging point I want to have the car start charging immediately
Is there a way to do this? It seems like a logical use case...
At the moment I have a plan configured that make the car charge during off peak hours, but charging it in a public charging point is a pain since I must rely on the MySKODA app which is... well... you know... crap :)
To charge immediately, when the engine is turned off a message appears on the screen asking if you want to charge at that time. But you have to be careful because if you open the driver's door that message disappears, you have to check the box before opening the door.
best regards
Hi you can do it, the option to do so is within the e-manager menu as shown within page 57 of the owners manual. Just focus on the days you want to do it and the charging times and ignore AC options etc. I ticked all days, repeat and set the time. I have a similar requirement to charge between 12:00 and 04:00 cheaper rate at 5p per kw with octopus. I have just set this up, plugged in the cable and it is not charging (i.e waiting for the correct time) so working as hoped. You can override the set time at anytime to charge immediately if you need to, this option again will appear in the e-manager screen.
