Skoda Scala 2020 Brake Fluid Reservoir
Tried to find my brake fluid reservoir on my Skoda Scala 1.0L TSI engine 2020 but couldn't.see it anybody any ideas?
It does not need topping
Thank you for the advice...much appreciated...
  • Sponsor
Isn't this it?
Yes found it in the end...initially thought that was power steering fluid ...but checked the symbols online...just need to find power steering reservoir now if visible...going on holiday with two elderly parents tomorrow to Cornwall so just wanted to make sure I had checked everything
Power steering is electric, there is no reservoir.
All check items should be covered and their locations identified at the end of your owners manual.
Similar to this from the Kodiaq manual…..
Edited by Kenny R
Many thanks for your help and diagram...mine is a 2020 model so the brake fluid reservoir is to to the left of the coolant reservoir
  • Sponsor
The different position is because the manual shows a LHD car.
My diagram as said is an example from a Kodiaq manual, your proper locations will be in your manual.
Got it thank you
