Fuel Gauge not Working Replaced Fuel Pump
Hello. On my Octavia MK2 the Fuel Gauge is not working. I replaced Fuel Pump with new one, 12v Circuit is ok (i checked the Connector with Multimeter). What else could i do? Maybe Relay? Than you!
It may be an instrument failure, probably a cracked solder join in the cluster.
Why!?
Because i was shure that the Float is the problem. Now after replacing the Pump sometimes Gauge is showing full, sometimes empty, sometimes analog pointer shows full and digital numbers half full...?
Any idea anyone?
