Replacing door lock mechanisms - DIY?
Recommended Posts
Hi, I've got the apparently common problem of doors not locking when stationary, and the repeated (and very annoying) locking attempts as I pass 12mph. Took it to skoda dealership, they told me all 4 locks need replacing - at a cost of £1500! Devastating thing was my warranty had run out a week earlier, I'd actually been intending to extend as soon as it expired but got my dates wrong.
So, wondered if anyone knows how I can find out what is involved in replacing them and assess if this is something I can do myself. Sidenote, if anyone knows how I can identify the correct parts to order and where to get them from would welcome the info.
  • Like 1
Link to comment
Share on other sites
Sounds like a very favourable diagnosis from a profit point of view, but an incredibly improbable one in reality.  More likely a single broken wire between drivers door and a-pillar, or something similarly trivial. Don't even attempt to order anything before getting some second opinions! Lock module replacement can be quite a faff, not sure how bad on a Superb3.
What year is the car? If it's only just out of warranty, and 4x lock hardware is being described as in need of replacement, that sounds very much like a case of 'not fit for purpose' whether or not they are actually really broken, so ought to qualify for considerable if not total goodwill cover.
  • Like 1
Link to comment
4 locks... no, just no.
that is a case of they can’t be bothered to do a proper diagnosis and instead throw a blanket over it.
If that was in warranty you think Skoda CZ would pay out for 4 door locks without proof of exactly what would be the cause.
take it elsewhere, I’ve had similar issues when a door module has been incorrectly coded after a latch was replaced.
did you get a copy of the fault codes or anything
Link to comment
I've had that twice in 3.5 years of ownership, but only on the driver's door.
Both times the (unexpected) cure was to charge the battery.
A TV engineer (ex-mechanic) pal suggested there may be corrosion somewhere in the circuit that means a higher electrical resistance leading to problems with a low battery voltage.
Worth a try?
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
