Octavia MK1 1996 airbag problem
Hi, i have a octavia MK1 from 1996 with a airbag problem. The airbag light has been illuminated a couple of years and i decided to try to fix the problem since they changed the rules so it is no longer allowed to pass the government inspections with the airbag light not working.
I visited my local mechanic that said i had a faulty airbag controller. So i ordered 2 used one from ebay but the "new" airbag controllers seam to think that my car has a passenger airbag but my car only have a airbag in the steering wheel.
Instead of faulty controller i now just get error code 00589 "Front passenger side airbag igniter 1"
I have have disassembled the glove compartment and there are not airbag mark on the dash and their exists not airbag and from what i can se airbag harness behind the glovebox.
I found two loose connectors but not sure if any of them are for a airbag or even if i am helped with that.
Is it possible to tell the controller that their is not airbag or can ai know if I buy a used one if it also think that there is a passenger airbag?
Or what are my option?
Is it possible to code the airbag controller to not think it has a passenger airbag?
  • Administrators
I think it can be done with a resistor, but someone who actually done it would have to confirm it as I'm not 100% sure.
Even if i find out what resistor i need I am not sure where to place it
  • 8 months later...
Solved it by buying another airbag module from ebay where the seller could confirm that the donor car only had one airbag.
