Scala SEL Ambient Lighting
Hi I have just purchased a 2019 Scala SEL would it be possible to retro fit ambient lighting?
You don’t need it, believe me.
The light on the dashboard is se weak that it should be pitch black to be able to notice that there is ”ambient light”.
Ok thanks, we had it on our Octavia and it was really good. Is it different on the Scala? Also we had a light underneath the door. It looks like there is a cut out for it, do you know if that can be retro fitted?
Thanks for the reply
The scala have in the foot area, door pokets and handles, dashboard and on the central console where is the wireless charger.
All is good except the one on the dashboard. It is not like on the new octavia or superb (like strip that glows in different colors)
On the Scala is a mini-tiny leds that are hiden under a plastic on the dashboard and they just produce little light that reflects on the black dashboard. Imagen how much it reflects… While on octavia and superb it is glowing directly like a strip.
I dont know if can be retrofited, i guess it can but its not worth it.
Better to buy cheap ones from ebay with different colors.
Edited by Wiegott
Thanks for explaining that. I’ll have a look around. 👍
Just forgot to mention that it is only one color - white, red or yellow.
You can not change the colors. If you install white one it will glow only in white. Same with the other colors.
That’s great thanks again.
