Airbag error message
Airbag light on and message ... error airbag. Came on for no reason.
You need it read with diagnostic tool, and they do come on for a reason sadly.
Just bear in mind you need someone with Hex CAN v2 as you have a newer car.
Cheers, guessed it was bad news!!
Could just be a single wire causing trouble, just you need to use a scanner to locate which airbag is faulting, and what code is stored to find the fault (short to Earth/open circuit)
It might even pay you to invest in a VCDS scanner, given cost of dealer visits.
It can't be any of your suggestions as the OP has stated it came on for no reason
The vehicle must be haunted 😆
Editted, I see you have already corrected him 😳
Thanks for info gents. I'm a bit ancient for all the tech so regretfully booking into vw dealer. It it was not an MOT potential failure I wouldn't bother.
You might be better to find an independant, dealer might follow the diagnostic software chapter and verse..
"Needs a new XYZ" So open wallet surgery.
