2010 Skoda Octavia VRS MK2 FL Front Side Light errors
hi Everyone, need abit of advice here.
My original DRLs died and i replaced them with a pair from Aliexpress with 2 x connector pins. This set lights up fine but will not dim as there are only 2 pins. Shortly after this, i got a front side light error in the display for both the left and right light.
I managed to buy replacement DRLs from DEPO with 3 x connector pins. These lights light up fine as well but they do not dim and the error messages for the front side lights did not go away too.
My mechanic suggested that only the original set will be able to remove the front side lights error. However, i no longer have them. Any suggestions on how i can solve this front side light error issue? Any chance to code this away in VCDS?
Thanks alot.
