adding a subwoofer
Hi all
Need help urgent
so long story short i installed an amp with a small sub in the boot. I ran 2 pair of speaker wires connected to the back of the head unit which is a columbus. No sound system and checked in vcds speaker monitoring is switched off and and equalizer is linear. If i select my car for equalizer then it clips at just over 50%
while playing about in the boot connecting the wires to a cheapo passive line output converter i noticed i was getting sound out from the sub by just connecting the 1st wire which i cant remember was positive or negative and it was loud, when i connected the other wire the negative sound level came down to normal. So i feel the sub isnt phasing right, its just not hitting the low notes quite right, much more of a mid bass sound.
So my question is for any sound enthusiaists, does this sound like a short in the speaker supply wiring, that i managed to make subwoofer play on 1 single strand of wire?
2nd does anyone have the exact colours of the front speaker wires at the back of the head unit as someone suggested there maybe a bass limiter on the rear outputs, so may as well try a new pair of speaker wires and connect to fronts
