Central locking interior switch not working
The interior switch to lock the car doesn't work, however, when using the key fob the car does lock.  There is no illumination of the switch or anything but the hazard lights and the rear window heater does illuminate orange when switched on. I was messing around with some VCDS settings for the alarm beeping so maybe I coded the wrong thing?. Much appreciated.
Please note - I am not a mechanic or expert in anything.
Hi, welcome.
Have a look at what information is in the car's Owner's Manual about the button and related locking. - https://manual.skoda-auto.com/004/en-com/Models
For the VCDS, I don't know the system at all but thought I'd seen that it keeps a log of amendments/adjustments/adaptations  so you can go back to them(?) - but - there's a section on this site for VCDS so you might be better asking about that there for those that do know the VCDS. - https://www.briskoda.net/forums/forum/23-diagnostics-amp-vcds/
HTH.
Edited by nta16
ETA: Please note - I am not a mechanic or expert in anything.
Ok, thanks for your help
