Help! Fault Code Woes - P1065 - Who has a VAGCOM Scanner?
I have a P1065 Fuel Pressure Regulation Discrepancy Fault Code and associated 'into limp mode' problems. This comes at the end of a long saga of a breakdown in Italy ending eventually with a new high pressure fuel pump.
My mechanic now reckons that the 'base parameters now need resetting' (his words) and he doesn't have a dedicated VAG scanner to do the job.
So can anyone out there recommend a person/garage that has AVAG scanner and could do this for me (Bolton - Bury - Manchester area).
Thanks in advance.
Trenchman
