Anyone who replaced the Adblue line from the injector and back to the Adblue tank?
I’m trying to replace the Adblue line and can’t figure out where it’s connected in the back. Anyone here who has done this job?
Sorry not a clue.  Someone that knows about them might be along.
Obviously you are replacing it for a reason, can i ask what is wrong with the one on the car?
I hope it will solve this.
Did you not clean up the spill to find the source of the leak?
Advice given in previous thread.
Yes I did and the leak is coming from this part that’s why I want to replace it.
I’d start by putting the car on axle stands then remove the plastic under shield then look from below as surely it’ll travel to the rear of the car
The feed/return pipes?
I managed to replace it yesterday, it was the feed line.
Nice work 🤝
  • 4 months later...
Hi. Did this solve your problem and which part no did you need for the feed line, was it easy to fit?
Yes, that solved the problem. I bought this: https://www.skoda-parts.com/spare-part/3q0131984ac-ad-blue-line-front-skoda-39383.html
It took two hours and the most problematic part was at the back I wanted to avoid taking down the fuel tank so it was very tight but it worked. Tape the new one to the old one and pull from behind. Good if you are two people in certain moments.
Thank you so much 👍
