Maintenance requirements 170 TDI CR DSG
Hi All,
Decide to keep my superb - 160k mileage. The car would go for big service tomorrow in the local trusted garage. Cambelt and water pump were replaced at 76k - and four years ago. I think it should be replaced now again - that was booked. Oil,coolant and all other filters. Wonder if there is something which should be done. DSG was serviced at 140k. I was thinking about the air inlet and maybe egr required some cleaning etc ?  Any suggestions are welcome as I had the car since 2018 and really would like to keep it for another few years as I don't have any problems with it. Thanks.
Brake fluid, brakes, tyres.
Check suspension.
Air filter, cabin filter (fuel filter(?).
Check battery and alternator.
Air-con(?).
Personally I'd clean the MAF sensor and run a couple of tankfulls of V-Power before, during and after the service.
That's me out of ideas.
Spelled "delete"?
3 minutes ago, KenONeill said:
Spelled "delete"?
Wonder why? I never had got any problems with that car, so just looking for advice on what is worth checking or 'done' .
DSG oil change and filter clean/replace.
it’s every 40k, so it’s up to you but if you want to hold on to it. If not at 180k.
Edited by cheezemonkhai
