Windiw regulator
Hello,
I am new here, so mistakes will occur. I would like advice on replacing the driver's electronic window regulator.
Youtube will show you the job.  Search for Skoda Superb (or Passat B5) door panel removal,  or window regulator replacement, and you will find a range of explanations of varying usefulness. Ebay can provide the steel cable regulator mechanism on its own or already assembled to the metal door plate, as well as the electric motor unit.
Oh, and make sure you properly seal the metal plate back to the door panel, otherwise you will soon find very wet carpets.
Thank you .
I have a repkacement regulator, but the You Tube entries I have found, so far, are all for the Octavua, for some reason. I will try again.
Many thanks.
You can also try Passat B5, Golf Mk4.  They are all very similar.
Is this for the front or rear window?
