2023 Fabia Color spare wheel 16inch
Hi All
Looking at buying a new Fabia color model with 16 inch wheels
Was wondering about buying a spare wheel / space saver
Can find a Skoda kit including a 15 inch tyre , but can't see anything with a 16 inch ?
Does anyone know if Skoda sell a 16 inch spare tyre or space saver ?
Does anyone know what the Fabia comes with a standard ( e.g. puncture repair kit etc )
Thanks Steve
'Skoda spare wheels for Fabia are 15".  Steel 'saving space wheels' and tyres.  Not 'Space Savers.'
you could buy a 16" Steel or Alloy with the appropriate tyre to carry as a spare wheel.
Purchase the foam and jack kit from a VAG parts departments for perhaps a little over £40.
The OEM part number for the foam and jack kit is 6VA093860
Once you have the kit, see if one of your 195/55R16 wheels will fit in the spare wheel well with the foam and jack kit.
If so, then order a spare wheel the same size. If you order the tyre and rim separately, you can choose which tyre you want.
Using a non-directional tyre will allow it to be fitted correctly in any position on the car.
Alcar 6599 6Jx16 ET45 5/100 57.1 steel rim (from Fabia MK4)
https://www.oponeo.pl/felga-stalowa/alcar-kfz-6955#22920550
Alternatively, order a 15" wheel, ie. 185/65R15 fitted to a 5.5Jx15 ET40 rim.
Alcar 4055 5.5Jx15 ET40 5/100 57.1 steel rim
https://www.oponeo.pl/felga-stalowa/alcar-kfz-4055#23226439
https://www.mytyres.co.uk/rims/details?vehicleId=1360399348768339044&rimCode=ALCAR4055
Edited by Carlston
I've just taken delivery of Fabia Mk4 colour edition. They all come with a silly tyre "repair" kit which is about as much use as a chocolate teapot !  It only works with small to medium punctures and won't work if the puncture is near the edge of the tyre. And to make matters worse, you have to replace the sealant stuff every 3 to 4 years as it deteriorates. That'll cost you £50 plus at least.
I purchased a space saver tyre compatible with my 16" wheels from The Wheel Shop. - the wheelshop.co.uk   As well as the tyre you get a jack, wheel nut wrench, and toolkit bag. All excellent quality and nearly half the price quoted by my local Skoda dealer.
Many thanks John
Just had a look at the wheelshop.co.uk and found this , is this the one you ordered ?
https://www.thewheelshop.co.uk/product/skoda-fabia-1998-present-day-16-space-saver-spare-wheel-tool-kit/
Will I have to order anything else or does the colour model come with foam kit to store a spare wheel as standard ?
Looking forward to getting my new car
Thanks for your help
Regards Steve
Steve,
Yep, That's the one.  It doesn't come with any foam kit to store the wheel - I've just placed it in the circular space below the boot floor after removing the polystyrene foam packaging that had the tyre "repair" kit in it.  It fits in neatly and there is room for your car jack as well.
Hope you enjoy your new car - I've had mine 3 days and am pleased with it.  Setting up the "Virtual Cockpit"  to the way you like it is a bit of a challenge!  The handbook doesn't explain it at all. Best to Google "Fabia  Virtual Cockpit"  and check out some of the videos that have been made about it - some are better than others,
John
Managed to get dealer to do spare wheel kit from dealer for £160 with foam kit so went with that
2 weeks to go fingers crossed
Edited by steveeeg
Did you manage to confirm the tyre size for the space on a Fabia Mk4 please? The dealer supplied items infer it is a 185/60R15 yet the Fabia Comfort seems to come with 4 standard wheels of 185/65R15. Hopefully a 185/65R15 will still fit the space wheel well as it is only a few mm larger
Hi
Not got car yet , think they do different size options for spare tyre
Will update when I pick up car , but sadly still in Germany
Regards
My Monte Carlo, delivered a few weeks ago, came with 185/65R15 spare wheel. I opted for spare wheel and variable boot floor.
That size tyre has almost exactly same size diameter as the 215/45R17 tyres fitted to the car, well 0.4% of a difference, so no real difference at all.
