Rear seat base on 2021 hatchback
Trying to remove seat base but cannot seem to move the Isofix covers or left seat is there a nack to this ? Has anyone managed it before dont want to break plastic
Did you rotate the isofix covers to release them? Remove the centre covers and rotate the base slightly so it slides off the pin.
Once they’re out there’s two clips at the front of the seat either side of the seat you release by pulling sharply up. They do break sometimes so it’s worth having replacements if necessary.
Ps, definitely when you pull the front of the rear bench up do it sharply, ideally with fingers either side of the loop that engages in the clip. It’s basically metal coat hangar wire, if you pull slowly it’ll bend and then your seat will be a bit loose on refit, where a sharp tug should release from the clip without bending the wire.
Edited by sunshinedave
Was not sure hiw to remove isofix covers do you twist them seem to be different from other Octavia models.
Didnt want to break the plastic if possible
